Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers Logo
Posted on Dec 25, 2012
Tweaking settings for picture quality - Samsung UN60EH6003 60" 1080p LED HDTV, 1920x1080, Clear Motion Rate 240, 20W Stereo Speakers
My wii console makes intermittent sounds, for example on dance games part of a song can be heard. Disc rotating noisily - have tried ejected and reinserting disc and tried several different discs - all...
Your drive is probably out of alignment and probably needs replacing or tweaking. Check the disk and see if there is not an unusual rub mark on it. (To tweak you drive you will have to pull your Wii to peices and check the drive while the disk is spinning.
How to print a 4x6 picture from mfc255cw
It depends on the program you are using but when you go to print and next to the printer pull down box. Click on properties then go to the paper/quality settings select 4x6. That should be about all you need to do you may need to tweak a few more settings to get it how you would like it.
Thank you,
Lee
The picture quality of the camera is very bad on my mac. im trying to use skype. first i thought it was the lighting in the room but it has been like that since i bought it. how can i get a better picture...
Run the program to use this webcam. In that you would be able to set up various items like color, hue, contrast etc etc. tweak all of them and set the best possible picture. Also rotate the ring around the lens. Both clockwise and anticlockwise to focus on to you to get the clearest picture.
Picture Quality
Clean the lenses and mirror. - Carefully with no liquid, just a micro-fiber cloth. They can be accessed by removing the front screen.
There are items in the service menu that can tweak color drive and grey scale, but you can really mess up a TV if you do not know exactly what you are doing. You can also do a comprehensive convergence in the service menu.
1helpful
Loud static
The set isn't fully tuned into the channel the satellite receiver is outputting on (should be channel 3 or 4). If this set is old enough it may have a fine tuning adjustment that needs to be tweaked a little to clear up the problem. Some Zenith TV's also had a switch to select different tuning systems. If set incorrectly this might happen. If yours has such a switch, make sure it's set to "normal" or "air". It may also be that just due to age the turner isn't working properly.
It might be time to consider replacing that set. A new one would give you all the picture and sound quality your satellite can give you. Right now you're paying for quality you can't appreciate.
Hd quality
it sounds as if your need to tweak your picture settings from the menu you should be able to go to menu then select pre set setting and or tweak diferrant part for your viewing pleasure, it would seem they were off before you upgraded box to hd
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
How do I set my camera to get higher resolution photos?
Hey there kbbate, if you use REC Mode you can choose the Recorded Pixels, and the Quality Level. 6m is the best available setting for the recorded pixels, and the quality level is default set to best, however you should check to ensure it's settings. Note: you cannot select Recorded pixels if the Quality level is set to Raw. Also Raw (3000x2008raw,3000x2000jpeg) would techniquely be the best setting for your purpose. You will just have to do the tweaking on the computer, rather than have the camera sort it out for you. Good Luck!
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
