This Casio error code normally means there is no programming in this machine and it is waiting to be fully re-programmed. If the machine is new, this is normal since it will have no programming yet.If you need an SE-S300 programming manual, one of our users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
SOURCE: casio se s300
SE-S300 is having an "Electronic Journal"
1. Key turn to X
2. Press [RC] until u see "EJ"
3. Press [CA/AMT TEND] to print the journal
SOURCE: i want to reset this casio se s300...how can i do?
Reset what? If you mean the daily report, then turn the key to Z mode and press cash. If you are talking about removing programming, it is best to edit the existing programming so you don't lose system settings. If you need a manual, there is one here http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
SOURCE: we have an error message
You have turned the key before finishing a task. turn the key back to the last position and the error should go away. Now finish what you started in that mode before turning the key.
If anyone is looking for a Casio SE-S300 manual,
OPERATION AND PROGRAMMING MANUAL
SERVICE (REPAIR) MANUAL
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_SE-S2000_SE-C300_SE-C2000_TE-900_TE-1500_TK-950_TK-1550_service_manual.html
SOURCE: I bought a second hand register casio se-s300. can
Turn key to PROGRAM mode.
Turn power off at wall.
Hold FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of FEED.
Press SUBTOTAL.
After power on. You are ready to get going.
SOURCE: plz solve my problem casio
If the register is new, this is normal, it just needs programming.
Otherwise, it may have had a lock up.
Try this:
Hold RECEIPT FEED down (may just be called FEED) - keep your finger on it.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
Wait for print out.
Turn key back to REG mode and try it.
If anyone needs more information, the Casio SE-S300 manual is here:
