I have a venta sonic vs370 and a vs207 that are really dirty with calcium deposits and maybe bacteria i would like to know if there is any safe way to clean them and disinfect
Use CLR on them to clean them and it will also disinfect them as well.
Calcium deposits can usually be cleaned up with vinegar, or go to a home center and purchase some lime-away (follow the manufacturers directions).
If you can allow parts to soak over night, it will help break the deposits free (depending on concentration, time, agitation, and temperature.). It may require several soakings.
To sanitize, sanitize the using a couple of teaspoons of bleach to a gallon of water. Immerse parts or wipe with a cloth soaked int he solution. Rinse with clean water.
Every 10-14 days, the lower housing should be wiped out with a damp sponge. The disk stacks should be rinsed off and/or brushed off with a brush or sponge. Periodically, the Venta Cleaner can be used for a thorough cleaning. At all times, care should be taken to keep water away from the motor. Please see User Guide for more information.
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
the reply i have received for my original question was for a venta air washer what i have are vs370 and vs207 ultrasonic humidifiers sorry if there was some confusion
