Computers & Internet Logo
A
Anonymous Posted on Feb 10, 2018
Driver hl-dt dvd ram gsa t50n ata device stop working
I check the device and it working properly, but it doesn`t show up on the computer screen. I downloaded itunes and thats when the problem started. I restored my computer to a new date and the driver reappeared. I than downloaded itunes again and the problem reappeared. Is there a solution.
goneforever.
Level 3:
Top Expert:
  • Lenovo Master 14,531 Answers
  • Posted on Nov 04, 2018
goneforever.
Lenovo Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263627
Points
66315
I guess he means the DVD ROM Drive is dead.
his typo RAM is ROM. ok>?
no OS stated, XP will love to fail any SATA device.
endless chips not supported.
no PC even stated, nor OS stated,
any answers will be wrong, lacking such KEY FACTs.
for sure back to FEB,2018
my guess is he runs the virus magnet XP
and the endless Infamous upper and lower filters are dead.
next time POST the OS.
then tell what fails, the DVD drive fails. sure it does
on XP, many do, as XP has horrible support on DVD drives.
for sure newer one.
XP is now dead.
XP has no support for most SATA chips and USB and Optical media, all newer chips and devices XP does NOT SUPPORT
nor will it ever support vast things new.
its 17 years old now. and support ended long ago.
4 years ago.
Carlos L. Glez
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Lenovo Master 419 Answers
  • Posted on Nov 02, 2018
Carlos L. Glez
Lenovo Master
Level 3:
Loyalty:
Answers
419
Questions
Helped
79907
Points
1953
Hello, is interesting several months ago I was same issues with Lenovo laptop, I tied different solutions, but in my case, I did a factory reset since (0), but you can try the solution recommended for support. microsoft, good luck! support microsoft com
5 Related Answers
Anonymous
  • 589 Answers
  • Posted on Jan 09, 2008
SOURCE: GMA 4082n device driver not working properly code 39
Please post the exact model of the notebook, as there are several models in the A60 series.
Anonymous
  • 43 Answers
  • Posted on Sep 18, 2008
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Oct 01, 2008
check whether the device is detecting properly on bios or not
Anonymous
  • 3940 Answers
  • Posted on Jan 04, 2009
SOURCE: HL-DT-ST DVDRAM GSA-T20N ATA Device
Here is the microsoft solution
http://support.microsoft.com/kb/314060
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Sep 13, 2009
SOURCE: HL-DT-ST DVDRAM GSA-T20L ATA Device Code 19 My
sure ...just look for the driver on your laptop site ..and reinstall it ...this should fix the problem ..if not ...restoring the OS or reinstalling it will fix it too
Testimonial: "Ta ! Very kind of you."
HL-DT-ST DVDRAM GSA-T50N ATA Device does not work and shows error code 31
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps
Hi can't read any DVD or CD anymore I got Windows 7 HL DT ST DVD Ram GSA T50N Ata
First check in bios under boot device priority if cd dvd drive is listed or not, if not then reseat the dvd drive, if yes the follow the steps.
1. Uninstall the cd dvd drive from device manager and also ATA Channel0 and ATA Channel1 and restart the compter, and then check.
2. If the above step doesnt resolve your issue then
In the run box type regedit, go to HKEY LOCAL MACHINE - SYSTEM - Control Set001 - Control - Class - {4D36E965-E325-11CE-BFC1-08002BE10318} - On the right hand side check for upper or lower filters if you find one delete it.
Do the same with Control Set002 and Current Control set.
Restart the computer and you will see the issue is resolved for sure.
7helpful
HL-DT-ST DVD-RAM GSA-H55N ATA Device doesn't work
That's most likely your upper/lower filters, or drivers acting up.
Try drivers first, as they are easier and faster to fix. Go to device manager under system properties, and uninstall the device and reinstall it.
If it doesn't work delete the upper and lower filters:
Press windows and R keys type in "regedit" and press enter
double click on "computer" on the new window that came up
double click on "HKEY_LOCAL_MACHINE"
double click on "SYSTEM"
double click on "CurrentControlSet"
double click on "Control"
double click on "Class"
double click on "{4D36E965-E325-11CE-BFC1-08002BE10318}
1helpful
SecurDisc HL-DT-ST DVD -RAM GSA-H55N ATA DeviceDevice not recogni
Your dvd lens needs to be clean from dust. Clean the lens of the drive by using a cd/dvd lens cleaner. You can buy it at any computer stores. Reconnect the drive from your computer.
My A205-S5855 would not boot. I used RECOVERY disks and got system up and running...BUT now the A205-5855 will not recognize the HL-DT-ST DVDRAM GSA-T20F ATA Device (DVD-CD Drive). I reinstalled drivers...
Sad news when ANY company SELLS SYSTEMS but offers such poor driver support!
TRY this YOUTUBE link:
Solution HL DT ST DVDRAM GSA T20N ATA CD DVD device has disappeared
Also be sure to check the other links offered at that address too... in the TEXT replies.
Hope this helps!
Anthony
7helpful
2answers
DVD Drive not reconized,"HL-DT-ST DVDRAM GSA-T50N"
Dear Sir,
It is not problem with your hardware,it is problem with your operating system. This happens due to invalid registry entry on the system files,you may clean the registry by using glary utiliy or any other free registry cleaning software,it may solve your problem.If it is not you have to reinstall windows operating system by formatting your system drive.
if you find any difficulty post a feedback,we will glad to assist you.
I think it helps
Have a nice day !
good luck
2answers
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
Just follow the instructions and it may solve your problem
1helpful
2answers
My Cd-Rom doesnt work for my Acer Notebook 2930
Did it give any error code, like Error code 39? And does the DVD/CD Drive appear in My Computer?
Normally the CD drives use the default Windows drivers. Try right clicking the HL-DT-ST DVDRAM GSA T50N ATA Device in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error, it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
1helpful
4answers
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
