Question about E-Machines eMachines Desktop PC
Motherboard wiring i replaced the motherboard of my emachines t6522 and i got all the wires hooked up right except the power. there are three, a red and white, a black and white and a green and white. looking down at the motherboard can you tell me in which order they go
  • 4 more comments
  • birm Jan 16, 2009
    the black/white has power sw on it
  • birm Jan 16, 2009
    the pin set up is ::::., so would it be green/white next to red/white next to black/white?
  • birm Jan 16, 2009
    thank you for your help..i hooked them up and we shall see.
  • birm Jan 16, 2009
    hooked everything up and turned the computer on......the fans constantly run, the green light on the front is on but nothing else. i cant even shut off the computer except by unplugging it.
  • karead105 Jan 16, 2009
    Were you able to resolve this? I have the same problem, I believe there is a problem with the switch since this is the second machine of this type that has a power switch problem that I have. I replaced the push button switch with a toggle on the first one but it looks cheesey and you have to fip the toggle several times for it to work.
  • birm Jan 16, 2009
    i have yet to solve the problem..i ordered a power supply replacement and when that comes in i will see what i can do.
  • 15,935 Answers
Green/wht normally = Reset or Power LED
Red/wht normally = HDD LED
And is the third red/BLACK?
There should be a label on the black pin jumper at the end of each wire.
Does it say anything?
Posted on Jan 16, 2009
  • blueextc3221
    blueextc3221 Jan 16, 2009
    Then the Black/White is the power switch jumper. The motherboard is labeled for jumper settings. Usually they are aligned : but some m/b are jumpered ..
    Simply look at the motherboard labels to figure out your layout.
SOURCE:
So well meaning person disconnected the three wires going to HD LED, Power etc..now I do not know what they were connected too originally.
Look along the edge of the motherboard for markings next to a set of pins. You may see markings to indicate what pins go where. Use the old board to help examine where the pins may be located. HD will go to your HD LED - Polarity will be important here, so when you get it wired, if it does not light you will need to reverse the wires on the pins. Power will go next to a Power indication, and the last probably will be a RESET. Once you get them hooked up properly, they should work for you.
You may be able to download the manual from here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Mar 21, 2015 | eMachines W3105 Motherboard Replacement...
How To Remove Front Panel For t5048 Emachines Tower
The eMachines T5048 Desktop PC, uses the NexGen 2 computer case.
(Also uses an Intel D102GGC2 motherboard)
1) http://www.hypermicro.com/mmhypermicrocom/images/CSEC004.JPG
The front panel is the Front Bezel.
It is removed by grasping the right side of it, and pulling out, G-E-N-T-L-Y
There Power On switch wires, Power On LED wires, USB front panel wires, Card Reader wires, etc., are still attached.
http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf
(Page 47 - Removing the Front Bezel )
{ Note*
Usually there are plastic tabs formed out of the Front Panel, and they snap into slots in the metal computer case frame.
Usually 3 per side. They are flat, and have a hooked end.
They are pressed to the outside, or inside of the case, to release the hooked end away from the side of the slot.
LOOK at the tab. Look at the hooked end. SEE which direction THAT flat tab should be eased over to, in order to bring the hooked end away from the side of the slotted hole.
When the hooked end is in the middle of the slotted hole, the flat tab can then be eased OUT of the slotted hole.
DO NOT assume all tabs go in the same direction }
[ The area of contact pins on the motherboard, that the wires from the Front Panel go to, (Except for the USB and Card Reader), is the Front Panel header.
This link shows you the Front Panel header pinout,
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-022441.htm
Click on the blue file name -
Intel Desktop Board D102GGC2 Product Guide - English (PDF)
{It's a Motherboard User Manual }
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 03, 2012 | eMachines T5048 PC Desktop
I need to know where 3 wires go
The wires should be labeled HDD,POWER, and i think RESET or somthing, just look on the motherboard within cord reach and you should see all three labeled on the motherboard all grouped together.
Oct 26, 2009 | E-Machines eMachines Desktop PC
Motherboard installation
Just download manual and check configurations:
http://www.opendrivers.com/driver/265244/emachines-c6415-user-guide-free-download.html
May 16, 2009 | Computers & Internet
Emachine T3958
Hopefully eMachines are consistent with their wiring/layout design, that being the case this diagram for T2898 (by benz18724) should point you in the right direction...
Alternatively compare the abbreviated pin symbols on the header to the motherboard and match them up.
Jan 31, 2009 | Computers & Internet
Emachines t6522
I assume you are trying to connect the wires from the faceplate to the motherboard. Get a magnifying glass and see if the board is marked as to Power, Speaker, HDD LED, Reset, etc. Trace the wires to the faceplate and note what the function of each pair of wires is and attach to motherboard as necessary.
Jan 17, 2009 | E-Machines eMachines Desktop PC
No power to emachines t6522
The final set of connections are the front panel leads that attach to the motherboard. This includes the LEDs for hard drive activity and power status, the case speaker, and most importantly, the power switch.
eg:
You should consult your motherboard manual to find out where to plug these in. The power one is obviously the most important.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | E-Machines (308714) Motherboard
Emachines t6522
Hi birm,
I can tell you that most likely the white wire is the ground wire. The others are positive. The two manual found on eMachine's site does not provide enough of detail.
In this manual see;
Replacing the front I/O Panel (Pages 168, 170 see number 5).
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The information is not specific enough, my guess is the front panel connections is the cable to the far right. (Looking at the picture).
You can try by looking at the picture & hooking the cable as shown.
The white colored wire seems to face to the right. Than try the power on button. If system does not come on, turn the connector 180 & reconnect. Try the power on button on the case.
Listed at the bottom of the link below you can either chat with a tech or call tech. (Main site for the T6522)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6522
User guide T6522;
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
Good luck birm!
I wish I could be more specific.
Mike
Jan 16, 2009 | E-Machines (308714) Motherboard
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
112 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
