Question about LG Optimus E405 White Unlocked 1GB 3.15 MP Android OS Phone
Screenlock code reseting for lock screen code for lg e 405
Need an override factory code to unlock screen lock on phone
    New Friend:
I have locked my screen them after five times it need to sign in with google and i havent a gmail.
what can i do?
Posted on Mar 29, 2013
  • LG Master
  • 2,887 Answers
[Fixed] Android Lock Screen Removal
Best way to unlock Android phone is with Broken Android Data Extraction software that available on removing Android lock screen efficiently and safely.This software provide security function that helps Android users to disable lock screen Android is just a few simple steps away.You can help yourself to do the Android lock screen removal job in any urgent time without Google account or do factory/hard reset on lock screen Android.
Furthermore,Android Lock Screen Removal & Data Recovery supports to remove lock screen on various of Android phones,including Samsung,HTC,Lenovo,Motorola,Xiaomi,etc.
LEARN MORE
How to retrieve important photos from broken black screen Android devices
How to Recover Data on Android with Cracked Screen
How to Recover Contacts from Android with Broken Screen
How to Unlock Android Phone with Broken Screen
Posted on Apr 26, 2019
SOURCE:
  • 6 Answers
SOURCE: How do u reset the lock code on the lg 8500 chocolate
Dial #4357*4357 and that should give you the phone information including the phone number.
Posted on Apr 04, 2008
SOURCE: I forgot my phone lock code for my lg chocolate
okay you need to type the last four digits of you phone number which was the original code upon purchasing the phone, then press the pound button right after. type the four dgits and then immediently the pound sign. you might have to try it a couple of times before you get it. this is how many people are able to use locked phones that are stolen. my friend who works at a verizon fios taught me this when i locked and forgot my passcode.
Posted on Nov 16, 2008
prasanth83
  • 68 Answers
SOURCE: LG vx3300, I accidentilly set the lock code and now cannot unlock
HI Joe ,
relax look go to this link and you can download the pdf file http://www.scribd.com/doc/4876273/Unlock-Codes-All-Cell-Phones and you will find the solution for all your trobles with LG mobiles.
This would surely solve your issue.
Have a great day
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
Posted on May 13, 2009
SOURCE: forgot unlock code of LG KG195
lg kg195 unlock codes
Posted on Sep 03, 2009
SOURCE: forgot lock code on LG EnV, need to reset settings for donation
I had the same issue with the same phone. By pure luck, I tried the last 4 digits of the phone number last used on the phone and it worked!
Posted on Feb 14, 2010
How to unlock locked samsung phone
If you own the phone and forgot your code, you will need to reset it to factory defaults.
Jan 06, 2014 | Beyond rubberize Protector Hard Case Phone...
Tip
LG mobiles Test Menu, secret codes and tricks
Here are some common codes for LG cellular phones and there use. Use these codes at your own risk and note that these codes may or may not work depending on your phone model.
Following are the codes:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Sim lock menu (LG B1200): 1945#*5101#
Sim lock menu (LG 510W, 5200): 2945#*5101#
Sim lock menu (LG 7020, 7010): 2945#*70001#
Sim lock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select ‘SW Ver.info’
Code to reset phone :
- Phone without SIM
- Select ‘Factory Reset’
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
on Aug 05, 2010 | Cell Phones
Screenlock pin
Can find your unlock pin with IMEI...and Stop posting IMEI numbers in public forums.
Once the screen is locked, your option is to use Google and unlock it, if you phone is connected. If not, only hard reset.
Nov 23, 2013 | Sony XPERIA TIPO DUAL SILVER ST21a2 Sim...
Forgot lock code for LG Extravert , need to reset to factory default.
Steps to Reset Settings This will reset the phone to factory default settings.
  1. Unlock the touch screen by dragging Slide up to unlock up and touch the Menu Quick Key.
  2. Touch Settings.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter the four-digit lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. After reading the warning message, touch OK.
  8. Touch Revert.
for Steps to Restore Phone visit my Blog
http://pcgadgetdeni.blogspot.com/2013/02/factory-reset-lg-vn271-extravert-to.html
Feb 14, 2013 | LG Extravert MobiPhone - Black Verizon...
The vibrate setting has stopped working. Vibrate doesn't work at all. Is there a way I can fix it?
Please try resetting the phone but this will reset all the settings to factory default.
This resets the phone to factory default settings.
  1. Unlock the screen by touching Lock or pressing the Unlock Key on the left side of phone, then touch Menu to access the menu .
  2. Touch the Settings & Tools icon.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  7. Touch OK after reading the warning message.
  8. Touch Revert. A confirmation message is displayed briefly before the phone resets itself.
source: http://www.resetcellphone.com/solution/LG/vx9700-dare
Feb 22, 2011 | LG Dare VX9700 Cell Phone
I need the sim unlock code for my lg optimus p509
Hello, LG all models test mode:
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
- Phone without SIM
- Select 'SW Ver.info'
- Phone without SIM
- Select 'Factory Reset'
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | LG Cell Phones
My phone has locked me out i need a master reset code
IMEI (ALL): *#06#
- Phone without SIM
- Phone without SIM
Hope this helps!!
Aug 18, 2009 | AT&T Cell Phones
Need unlock
try this method and give me your feedback.
To Unlock KG800/LG Chocolate
1. Insert sim from the network that it is locked to.
2. Turn on phone
3. On home Screen, Slide up phone
4. Type 2945#*#
5. ENG. Mode menu should appear
6. Go Down to Factory Reset Select it, may take a few minutes to reset!!!!!
7. This will reset the phone back to before the Phone was locked to a network
8. The phone will automaticaly Restart(Note The Network Logo At start up will not change)
9. Now insert Any simcard(Not tested with 3 sims)and the phone should turn on normaly
10. The phone is now unlocked and you can customise the setting as you like
Apr 12, 2008 | LG KG800 Cellular Phone
LG Free unlock Code
do you know how to unlock lg kp500?
Mar 12, 2008 | Cell Phones
User lock on LG 4600
if you give me the imei number from underneath your battery on back of phone looks like 123456/344/344 about 16 numbers long if you give me this i can get you master override code and this resets the security code let me know if you need this every phone has different override code and the imei number lets me et the codes for you ok
Oct 16, 2007 | Cell Phones
LG Optimus E405 White Unlocked 1GB 3.15 MP Android OS Phone Logo
315 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
