Would this be a thermostat problem where i would need to replace it?
This sounds like a bad coolant temp sensor that give computer false reading, check the coolant temp sensor connector and if it is good with no bad wires to connector then replace coolant temp sensor , when the computer gets a signal from temp sensor that engine is hot it turns fans on high speed to cool radiator and displays a/c turned off , if this truck does not have electric cooling fans then they wont run just explaining what happens depending on engine and cooling set up. replace coolant temp sensor and check connector.
SOURCE: replacing pcv valve
driver side valve cover in the back of the cover. if it even has one, sometimes the cover has been replaced with a later style that uses a baffle instead of a pcv
SOURCE: 2007 chevy silverado 2500 hd duramax shut down
mo me it sounds like low fuel volume i would check my lift pump
SOURCE: Drain Engine Coolant in 2005 Chevy Silverado 2500 HD
there is a petcock at the bottom of the rad drain ti from there and use a antifreeze tester to check protection temp
SOURCE: how about advise on a 2003 chevy silverado 2500 hd
The instructions are below. Also, there will be a diagram for the routing.
To install:
SOURCE: display reads engine hot a/c
Sounds like your temperature sending unit is bad. If you need instructions for replacing the sensor, please let us know.
