When I turn on the projector, it stays in "warm Up" phase with the light flashing under the "on Button". The windows that normally open so the lamp can project remain closed. Non of the lights for heat or defective lamps are on, it just seems stuck in warm up phase. Have turned off the power and back on again to try to reset
FAULT1 EPSON EH TW PROJECTORS 5010 9000 9100 9200 and others:
power unit up standby blue led flashes the unit continues to run then the internal fan runs the front lens cover NEVER opens then the unit goes into protection mode with both leds flashing then you have to unplug unit so fault condition repeats
FAULT2 EPSON EH TW PROJECTORS:power unit up standby blue indicator flashes internal fan runs then the front lens cover OPENS with the lens cover motor still continuing to run and not stop despite being fully open and the lamp does not strike then unit again goes into error mode with both leds flashing JVSVisual in Birmingham repair all these known fault conditions Email John: [email protected] also see us on youtube.https://www.youtube.com/watch?v=4pkbl2-L7xM
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
SOURCE: Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
SOURCE: Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
SOURCE: ELP 3300 lamp problem?
probably. try to check the number of light hours( you can check the manual on how to view it) usually 10000 hours could mean that you need to replace the bulb. also check the physical appearance of the bulb, if it has cracks on the ceramic at the back, then you need to replace it.
SOURCE: My EPSON Powerlite 730c projector doesn't power up
epson will not sell parts to anyone who is not an authorized service center. sorry. if you can get the part from an asc, then you can replace it.
SOURCE: I have an Epson EMP-74 projector. When plugged in,
You have on short circuit in the apparate.Verify the lamp and the alimentation parts.
