MY IPHONE WONT CHARGE IT SHOWN THAT IT IS ON CHARGE BUT IT WONT MOVE FROM 1%
SOURCE: Why iphone doesn't go into DFU, restore or detect
If holding power and home for 6 secs. then releasing power (not Home) for around 10-20 more until itunes sees it. doesn't work try with the phone off, hold home button and plug in cable....itunes should detect the phone that way.
SOURCE: my iphone does nothing it wont turn on i charged
See if itunes can see it. If it can you can restore it. If not with the phone off connect it to the computer and hold the home and power button for 6 secs. then release the power button but keep holding the home button until itunes sees the phone. now you can restore the phone.
SOURCE: why doesnt my iphone charge when its on but it
You may have tried to charge your iPhone while it was powered off only to have it turn itself on as soon as you plug it in to the USB Cable or place it on the dock. As a result, it may have seemed that the iPhone insists on being turned on in order to charge.
As it turns out, this is not the case. Simply plug your iPhone in to charge while turned on (or off for that matter) and once it begins charging, power it down. If you power down after charging begins, the iPhone will remain turned off while still charging.
SOURCE: My iphone 3GS stopped working, suddenly it went
Try a reset. Hold the sleep button and the home button together until phone turns off and release buttons when you see the Apple logo. The re-boot should take a min or two. This generally solves a lot of problems.
Jim
