Question about Netopia Motorola 2247-n8 Wireless Dsl Modem Wifi Gateway
When I enable wpa psk I lose access to the router
Every so often I get bumped off my router and have to reconfigure it to get back on line. This time every time enable my security I lose access to my router (I get the the page not available error) and have to reset it back to factory settings again to get access to try configure again. Need some help... Please
5 Suggested Answers
SOURCE:
  • 30 Answers
SOURCE: Can't Access Netopia Admin Panel Via IE
Try this and see if it works for you. Telnet into the modem. Hyperterminal will work fine for this.
Type config, then hit the enter key.
Type set, then hit the enter key.
At this point look at your monitor. Does the bottom line look like this?:
autoConfig (on) [ off | on ]:
If so, type off. Then hold the enter key down for several seconds untill you get to lines that look like this:
Netopia-3000/xxxxxxxx (top)>>
Then type save and hit the enter key.
When the screen says that the configuration data has been saved, type exit and hit the enter key. Then type restart and hit the enter key. When the modem restarts close hyperterminal and access the Netopia using your web browser.
Posted on Apr 12, 2009
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
  • 85 Answers
SOURCE: i cannot access my router.
Here is a link that gives all the necessary instructions:
http://www.netopia.com/support/hardware/technotes/CQG_026.html
Posted on Jul 01, 2009
govinda123
  • 2276 Answers
SOURCE: unable to go online with WPA-PSK enabled
What is the operating system on the computrer ?
If it is Windows XP Sp1 then it will not support the WPA.
You can change the security to WEP.
Or you can update the Operating system to XP- SP2
Make sure that you are using the correct password while connecting to the network
Click Here to know more about routers
Posted on Nov 20, 2009
I need to find the WPA-PSK/WPA2-PSK passphrase for my cisco router
If you cannot remember your your pass phrase your only option is to reset the router back to factory setting sand reconfigure it.
On the back next to the WAN port is the reset button. Power off the router, press and hold the button, power on the router and continue to hold the reset button for at least 5 seconds. Allow th router to reboot and you should be able to access the router to configure using 192.168.1.1 with no loging ID and a password of admin
Good luck
Jan 31, 2011 | Linksys Wireless-G Broadband Router
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Using wireless router and wirelss dongle/adaptor on same pc
Sorry to say, but no you can't do WPA/PSK and WEP at the same time from a single wireless router or access point.
The simplest way to accomplish what you want is to buy a simple Wireless Access Point, configure it to use WEP, and run it when your son wants to use his NDS. Leave your existing router on WPA for your computer(s).
Ok, that's really the second-simplest way. The simplest way is to set it to WEP and reconfigure your computer(s) to use WEP instead of WPA, and leave it that way. That drops your security though, so you may not like that solution as much.
Nov 01, 2009 | Belkin Computers & Internet
Error code #052030
Error Code: 052030 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Oct 23, 2009 | Nintendo Wii Console
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
Connection to internet on wii system
try to set your channel to either 1 or 11.set also your router's broadcast setting to 'mixed'.place your wii near router with no interference from microwaves or such.if router setting is set up to allow only selected pc's (or mac addresses),don't forget to include wii's mac address to enable it to have access to the router.if your router password type is wpa,make sure also you know whether it's wpa-psk AES,wpa2-psk AES or wpa-psk TKIP,you need to consciously choose the right one on your wii internet setting.also,you could switch the dns ip addresses around like put 2nd ip address in primary and 1st ip address in secondary.no guarantees,hope this helps.
Mar 18, 2008 | Video Game Consoles & Games
To connect WII on line
if you have the mannual for the telus enchance wireless conector it should be in there but if you haven't got the mannual or if it's not in it, call up the servies number in the book and if it's not in it look it up in the phonebook.
hope this solved your problemo
good luck
***Glaceon***
Mar 17, 2008 | Nintendo Wii Console
Enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Enable WPA-PSK
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Netopia Motorola 2247-n8 Wireless Dsl Modem Wifi Gateway Logo
74 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
