Question about Hardware & Accessories
Setting the clock on a brinks timer 44-1011
Is there a manual for th is timer?
    New Friend:
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Posted on Dec 03, 2013
  • 2 more comments
  • Anonymous Feb 15, 2016
    thanks - surprising how they fail to set up keywords to find source articles
  • Alison Hicks Dec 01, 2016
    This is great. Thanks! :D
  • James Lindley
    James Lindley Dec 19, 2016
    Thank you. I was just trying to remember how to program mine and these instructions are perfect.
  • Robert Brown
    Robert Brown Mar 23, 2019
    Thank you so very much! Best instructions! You're a lifesaver!
5 Suggested Answers
SOURCE:
SOURCE: brinks 44-1030 manual i need a
1) Can you describe the timer in detail?
The buttons and the dial, shape, if it plugs in or is programmable, whatever you can think of to illustrate what timer looks like.
I have extensive files on timers
Most brinks timers are versions of other timers, and manuals exist for those timers.
Add a comment with the information, and I will post a manual if timer matches other brands.
2) You can open following link and see if your timer appears on the page:
Manuals appear for each timer on page with a few exceptions.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Another step would be to buy the 44-1030 at Walmart and scan the manual into .jpg format.
Download Cute-writer the free pdf software.
Print your .jpg image but select cute-writer as the printer.
Instead of printing, the software makes a pdf manual.
I use this technique when I need a manual
Title your new manual and post it on the internet for sale.
Return the timer for a refund.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you describe timer.
Posted on Jan 10, 2011
SOURCE: I have a brinks 44-1030
Manual is shown on links below:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1030-manual.pdf
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 19, 2011
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Mar 02, 2011
SOURCE: i have a brinks timer
1) Open following link to identify timer and download possible manual:
2) You can contact Hamptonproducts.com and they will send manual.
3) If you have a manual and cannot understand it, then add a comment and say what part of manual is confusing, and what you have tried so far, and what load you are wanting to turn on-off. Not every timer is right for every application, so clear identification of what you want to do is best.
Upvote the help.
And take advantage of fixya expert assistance live.
Posted on May 17, 2011
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How do you reset timer for brinks 44-1011
stick end of paper clip or toothpick into reset home to reset timer to faCTORY defaults
This will clear memory settings that occur during manufacture and testing
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/brinks-timers-and-manuals.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 13, 2014 | Hardware & Accessories
I have a brinks 44-1011 timer would like to know how to turn completely off when not in use. Turn the clock off and everything
Copy following link to help identify timer:
Frequently the timer restarts at next set point.
Only a few timers have full off-on by-pass capability.
Gene
h
Oct 12, 2013 | Hampton Technologies Brinks Timer
Lost manual for model 44-1020 need help setting it
1) Copy following link for possible Brinks timer manuals:
2) Add comment and describe timer in detail for possible identification.
3) Buy another timer from Walmart, with instructions, and return defect timer in new box.
Dec 14, 2012 | Hampton Technologies Brinks Timer
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Mar 02, 2011 | Hampton Technologies Brinks Timer
Hardware & Accessories Logo
25,392 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
