SOURCE: I have an '08 Kawasaki Brute Force 750 I bought
buddy diy easy to service 4 things oil,oil filter,airfilter,spark plugs and maybe coolant get back to me if you want to do it your self and i will go through step by step with you buddy
SOURCE: electric start cliking, lights flicker when running
if you have a volt meter, check the battery cables for voltage when its running. if you read above 12 volts, then your charging system is fine - replace the battery. if less than 12 volts, then you have a bad stator winding and will need to have the charging portion of the stator replaced. probably about a $300 part.
SOURCE: Hi, i have problem with kawasaki KVF750 brute force 2008,
sounds like could be exhaust problem. do anything new to it lately? also what kind of gas are you running and what kind of oil and tranny fluid. Check battery terminals make sure they are secure tightly.
Testimonial: "Thanks for answer, exhouse sistem is original, no innovations was doing, gas is 95."
SOURCE: SPARK PLUG SPARKS 1 AND STOPS NO MORE SPARKS AFTER
check the magnito for rust,If you stor something it will draw moisture and rust the mag so that it isnt making contact with the coil.
SOURCE: 2006 Kawasaki Brute Force 650, no power when key is on?
i have the same thing with my brute force what is it ??????
