I can still see funmood search behind my browser google chrome. I want to completely erase itI can still see funmood search behind my browser google chrome. I want to completely erase it
it might have to be uninstalled You should always remove and uninstall programs from your PC that you are not using. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer. Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.it might have to be uninstalled You should always remove and uninstall programs from your PC that you are not using. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer. Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
You can't post conmments that contain an email address.
Create the Menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options in the general tab tick in the box to delete temporary files history cookies and saved passwords
below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if dont need any of them you can disable or remove them
Start > Control Panel > Add Remove programs (or) Start -> Control Panel > Programs > uninstall a program Click on the Funmoods Toolbar and click remove
Reset your Internet Explorer Settings: In Internet explorer > Tools > Internet Options General Tab > Under Home Page > Click Use Default General Tab > Under Search > Settings > Select funmoods > Click remove
This guy did a nice little write up on removing "Fun Moods", if you need more information:
To remove funmoods from your computer, go to the Control Panel, then click on Programs and Features. Find funmoods Toolbar, click on it to reveal options, and then click Remove. It may be under another name. If that doesn't work, download Revo (the free version)http://www.revouninstaller.com/revo_uninstaller_free_download.html and see if that helps find and uninstall it any easier.
The problem is that most tools do not detect funmoods as there are several opinions regarding clasification of Funmoods. Lately, some vendors tried to add new detection techniques, so we would recommend using Spyhunter to get rid of funmoods.. Another good product to remove funmoods is MalwareBytes anti-malware.
Close all browsers and windows completely. Start menu >>> Control Panel >>>Programs and Features >>> find and remove "Funmoods Web Search". If that doesn't do the job, try this:
http://www.2-spyware.com/remove-funmoods.html
If THAT doesn't work, I can only blame your anti-virus protection at this point, haha. The recommendation I get from tech-savvy computer specialists all the time is to stick with Microsoft Security Essentials, 1) because it's free, 2) because it actually does an amazing job at cleaning junk out of your PC. McAfee and Norton Antivirus? LOL. Used to have both and they sucked. Anyway, hope this works out :)
1- Open your IE browser, click Tools, then select Internet Options. Click Restore to Default on General Tab.
2. Open your IE browser, click Tools, then select Internet Options. On the first tab labeled General, click Settings, then select your preferred search provider and click Set as Default.
3. Close all your browser. Go to Control Panel in your Start Menu. Click on Uninstall/Remove a Program.Find Funmoods Toolbar and click Uninstall. Restart your browser.
Hi, This is Nan from Community&Support @Funmoods and would like to offer you a set of instructions in order to uninstall Funmoods. In Firefox: To removetoolbar/New Tab Open Firefox, go to Add-ons Manager (Ctrl+Shift+A) > Select "Funmoods" and click on Remove To remove from Home page: Open FireFox, go to Tools > Options > on "startup" section click on "Restore to Default" button Then click on "OK" To remove from search engine: Search button--- Manage Search Engines---- select "Funmoods"---- Remove For a step by step uninstall guide, please watch our tutorial: http://www.youtube.com/watch?v=dT5PWzLDptc To remove from Internet Explorer Win7/Vista from toolbar: Go to Start > Control Panel > Uninstall a program OR Programs and Features > Select "Funmoods" and click on Uninstall To remove from Home page: go to Tools > Internet Options > on "Home page" section click on "Use Default" Then click on "OK" To remove from search engine: go to Tools > Internet Options > on "Search" section click on "Settings" > select "Live Search" or "Google" or "Bing" and click on "Set Default" > select "Search" and click on "Remove" > OK > OK New tab (Internet Explorer 8-9) go to Tools > Internet Options > on "Tabs" section click on "Settings" > on "When a new tab is opened, open:" select "The new tab page" > OK > OK In Chrome, to remove toolbar: Open Chrome, go to Options menu > Tools > Extensions > Click on the "bin" to remove To remove as homepage: Open Chrome, go to Options menu > Settings > on the "Appearance" section, check the "Show Home button" > Change > select "Use the New Tab page" To remove as search engine: Go to your browser----Click on the tools icon---- options------Change search defaults ----- settings ----- click the name of your preferred search engine---- set as default---- (to remove Funmoods search)----select Funmoods ----remove---- okay -Or- Open Chrome, go to Options menu > Settings > on the "Search" section choose Google on the drop down menu For a step by step uninstall and reset homepage guide, please watch our tutorial: http://www.youtube.com/watch?v=dT5PWzLDptc Hope this works. Nan
What likely happened is that you installed a program that asked you if you wanted to install Funmoods with it already checked. A lot of internet apps pull that ****. What you need to do is the following
Go to Control Panel > Programs and Features, or Add/Remove Programs on older versions of Windows.
Find Funmoods and uninstall it.
In Chrome, click the wrench on the upper right hand side of the page and choose Settings.
You should be on the Basics page. Where it says Search, click the "Manage search engines" button.
You will see that Funmoods is the default. Hover over another search engine until you see "Make Default". Click it.
Hover over Funmoods. You will see an x on the right side. Click it in order to delete it.
