When i am trying to switch on the mobile then the key light is tern on but the phone do not start.
SOURCE: phone dead after opening java executor
if you run executor, which is put on phone during patch unlock process, then this will tempory kill phone, the cure is to Flash the same main firmware back to the mobile
SOURCE: Sony Ericsson C902 unlock, Orange network
If you haven't made up a code already then the code is the last four digits of your phone number.
SOURCE: sony ericsson c902 orange unlock code
Use A2Uploader - absolutely free. Here's a guide:
http://www.akshayy.com/sonyericsson/tutorials/a2uploader-tutorialguide/#more-81
SOURCE: c902 doesn't start, blue camera light shines
flash your phone.i had the same problem,and after flash it worked fine. for tips on how to, go to http://forums.se-nse.net/topic/46338-a2-uploader-general-usage/
SOURCE: DELETED PHOTO
My friend its a very big process to explain how recovery data software works.But one thing i know that when data is lost it can be recovered by data recovery services. One of my friend use the data recovery service to recover Sony Ericsson mobile phone data from:
http://www.any-data-recovery.com/topics/mobile-devices/recover-samsung-galaxy.html
Anyway to view PDF files you have to download PDF Reader (Download links given below) or send it to your Sony Ericson and install the application.As far as I know this PDF reader supports the following Models
Sony Ericsson k750i
Sony Ericsson W810i
Sony Ericsson k800
Sony Ericsson p990
Sometimes you might get a "Invalid Application" or "Operation Failed" error, in that case try to re install PDF reader application! As Sony Ericsson mobile phones support .Jar file extension,I have uploaded the PDF Jar file to different file hosting!
check this lick for SONY mobile softwares.--http://ptf.com/sony/sony+ericsson+c902+mobil+software+pdf+reader+java+free+downlod/
thanks for rating
Good luck
