I just got an xbox 360 and everytime i play on live, i get disconnected after 30 minutes or so. It's really annoying and I've tried portforwarding, dmz, and upnp(universal plug and play). Not to mention that I did all of these separately to avoid any conflicts with disconnecting. Unfortunately, I still get disconnected with a "network connection lost" error. NAT is enabled. I tried to restore to factory defaults and still no magic. I have a belkin f5d8231-4 v3000 router. Any help would be much appreciated.
SOURCE: Belkin F5D9230-4 router with xbox live
I was having troubles with a belkin router as well. i called belkin tech support and they never helped as they would not accept that the router was the problem. i found i could connect the xbox directly to a modem and it would work fine but when i connected it through the router it would always disconnect from games or not allow me to join a game, only host them, with no one else joining. no matter if i forwarded the appropriate ports, put the specific ip address into the dmz or even turn upnp on (i've tried different combos of each, all on at same time, to even setting up manually) and nothing would change. I found that the router had an option to turn off NAT which belkin told me would render the router useless. I decided to go against them, turned it off and set the ip and dns to go with the modem. Now everything works fine as the router just acts as an expensive multi plug and wireless system. all the computers in the house can connect to the internet at the same time and access eachothers hard drives and i can access xbox live fine with no problems. there is also no lag when playing gtaIV multiplayer with 15 other players. i hate belkin tech support and i will not pay for another expensive multi plug connector from belkin... ever.
the solution is as such, first log into your router by typing the routers IP (192.168.2.1) into your browser.
The first thing you want to do is set UPnP to be enabled.
Forget about the 88 UDP thing, it's bogus.
Just set the TCP and the UDP to 3074 in virtual server.
I swear to god it will work.
SOURCE: My Xbox 360 Nat is Strict. with my Belkin
again give it then save it then reboot it the router then try it
SOURCE: belkin n1 F5D8631-4 NAT goes back to strict after been open
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step
2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet
explorer
Step 3 : On the left side Click Firewall
Step 4
: Leave the Password blank and click Submit
Step 5 : Disable it
And Apply Changes
Step 6 : On the left side Under Firewall
Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step
8 : Click Apply Changes
Step 9 : Restart the Router
Step
10 : Test the Connection
SOURCE: Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address
bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more
information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your
internet service and ask them to bridge the modem
