HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop date and time setting get disturbed automatically
HP Pavillion dv-1125nr laptop date and time setting change automatically to a wrong value. Every day I have to set it to correct value.
Any solution?
:Shailesh
  • 2 more comments
  • kumargov Mar 09, 2009
    My laptop date on every reboot changes to 1/1/2004 ,after which i need to manually change to original date.i checked with technician but they told no issue with internal battery...my laptop odel is toshiba satellite M 40X
  • gowsi2003 May 16, 2009
    pleaseee help me...i got the same damm problem..yesterday it was working soo good, internet fast, and computer fast...but today morning i turned on and it is sooo freaking slow...swear to god i was soo close to smashin ma laptop into tiny *** pieces...please help...my time and date changes also...also please tell me how i can stop pop us and AUTOMATIC PLAYING VIDEOS ...i recently downloaded kaspersky 2009 the trial version but it didnt stop...i went to serial.ws....to get cd keys but these bad videos :P started playing..i closed one and 100 website opened...I NEVER HAD THIS KINDA AUTO PLAYING POP US ....but i did once got virus that opened one after anotherrrr windows......and froze ma comp as 100 windows were opened...
    pleaseee help mee...any solutions...
  • Anonymous May 11, 2010
    have you checked the time zone setting to see if it was set correctly?
    What is the age of the laptop. That sounds like a cmos battery issue.
Muggs01
Level 2:
  • Expert 72 Answers
  • Posted on Jan 16, 2009
Muggs01
Expert
Level 2:
Answers
72
Questions
0
Helped
59609
Points
189
Do you plug into a network with a server if so set the computer to not change time to server time.
Factory reset for HP 2000 running Windows 8
a clean wipe of the partition and reset can be accomplished in the Bios functions, simply go into set up at boot and move through the menus until you achieve your goal. HP is well known for installing ghost partitions on their hard drives .
Lenovo laptop z560
Your computer's clock is used to record the time whenever you create or modify files on your computer. You can change the clock's time and time zone.
  1. Open Date and Time by clicking the Start button, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
  2. Click the Date and Timetab, and then click Change date and time. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the Date and Time Settings dialog box, do one or more of the following:
    • To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
    • To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
    • To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
  4. When you have finished changing the time settings, click OK.
  5. To change the time zone, click Change time zone.
  6. In the Time Zone Settings dialog box, click your current time zone in the list, and then click OK.
    Note
    • If your time zone observes daylight saving time and you want your computer's clock to be adjusted automatically when daylight saving time changes, make sure the Automatically adjust clock for Daylight Saving Timecheck box is selected.
  7. Click OK.
1helpful
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
I have an HP Pavillion dv5-1125nr. I haven't
hi,
seems your cpu fan is damaged .
i suggested to contact an expert technician to repair the necessary damaged devices.
pay attention : don,t turn on your hp till refer to said technician.
good luck
gorbesia
1helpful
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
How can i resolve a bios checksum problem with my hp pavillion dv 2000 laptop
A BIOS checksum error is usually related to a near flat BIOS battery.
Replace the BIOS battery then boot up the laptop and go into the BIOS configuration and set the Date and Time settings etc. and the checksum error will disappear.
Black screen on my HP Pavilion DV2000 Laptop
for all dv i think it depends with the area u are staying coz from Africa here there is no warranty for any pavillion esp those dv 2000,6000 etc
bt wht u can do is to try to reset the system by removing the battry and power thn u press the power on batton 4 i min,thn put evrthin together
2answers
Blue Screen trying to load XP on HP pavillion dv4-1125nr
It should have an error code in there somewhere on the screen where it says it's shutting down.
Type that error code into Google and you'll find an array of answers. There's a bunch of things that can cause the problem you listed, but we don't know which one.
Optima EP721 DLP and HP Pavillion dv 6000 laptop
if you are wanting to connect ur laptop to an external display then you have to go the control panel, then display properties and change the resolution since ur laptop screen's resolution and external display's resolution might be different. most of the computers with vista automatically adjust that but in xp, u might have to do it yourself.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
