Responds to change the tv remote with the cable company or the TV itself was watching tv and the picture went out, you hear the sound, I turn off the TV and went back to turn on, the image turns on but only a second, the sound is heard, as I did with the remote reset and nothing just a second and the video will only sound and black screen, everything works normally only imajen that lasts a few seconds and turns off
SOURCE: Sanyo LCD TV DP32746 no picture
Easy way to Diagnose is get a known good CCFL from a laptop or LCD TV and start plugging it in to the existing Cathode's Ports one at a time. Generally its a bad CCFL on these multiple units.. (2,4,6) Bulbs.. Moniserv.com for replacements.
Goodluck guys!
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
SOURCE: last night watching tv, picture cut off (black
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: Sanyo dp42848 turns on, picture comes on then goes
Sounds like a loose connection to the display panel. Did you physicaly move it from the time it didnt work to the time it started working..
Hi Sandy
Yep, after doing a little more research, I've come to the same conclusion, however they have more than half a dozen different Back light inverters for these Sanyo units, hopefully its not the most expensive one and not the one my supplier does not have in stock, trying to give my customer an estimate, hopefully I don't have to shoot too high. Thanks for the info.
