Watches Logo
How to adjust the minute hand and hour hand of the casio marine gear AMW 710 model
My son bought this watch from Dubai. When he went sent this watch to the Philippines the time is delayed of 4 hours. No manual included and i find difficulty in adjusting the watch.
5 Related Answers
Barbara Phillips
  • 29 Answers
  • Posted on Mar 10, 2008
SOURCE: Setting Time
Hold in the adjust button until the seconds start to flash. Then push the mode button until the hour is flashing. When the hour is flashing push the forward button to advance it one hour. After you do this hit the adjust button to exit the set mode.
Anonymous
  • Posted on Jan 20, 2009
SOURCE: lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Aug 10, 2009
SOURCE: The analog portion of my Casio watch has a
You will need to remove the crystal, but without proper watchmaking tools and skills you will not be able to do the job. If you do not want to damage your watch, you have to find your nearest watch repair shop and ask to fix it.
Anonymous
  • 945 Answers
  • Posted on Oct 22, 2009
SOURCE: I have a Aerospace model watch and am having
Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
I think you might have not moved the minute hand forward 5 mins and back.
You can now set your digital time from your hands setting.
Testimonial: "Thank you and I will try your suggestion. Appreciate your help. Regards"
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 23, 2010
SOURCE: how to set the hands to adjust time
Find manual for your Casio in my tips and tricks.
1helpful
How to make my Casio watch band smaller ?
To adjust the dual time on your Tommy Hilfiger watch model 1791709, follow these steps:
  1. Press the "Mode" button to enter the dual time mode. The dual time mode is indicated by the small "D" at the top of the display.
  2. Hold down the "Adjust" button for a few seconds until the hours digit starts flashing.
  3. Press the "Adjust" button repeatedly to adjust the hours of the second time zone.
  4. Press the "Mode" button to move to the minutes digit, which will start flashing.
  5. Press the "Adjust" button repeatedly to adjust the minutes of the second time zone.
How to set time
This should help:
https://casiowatchparts.com/how-to/adjust-time-on-casio-amw-700/
I bought a casio watch (model AMW-320R, I think that is the model number) with both a tradiotnal hour, minute, second hand and digital readout. The digital readout is fine but the second hand on the...
Normally this is the battery... Try the battery before considering to send the watch to Casio for service. Or, if you send it they will fix it and send it back. They are not very expensive for their service.
1helpful
How do i adjust the time on my casio amw 704
Record your module number from the watch back, then go to this link:
http://world.casio.com/wat/download/en/manual/
I hope this helps you. Thanks.
2helpful
How to adjust analogu time in casio 3768 amw-200
If you haven't got a manual, then you can find it by going to the Casio web site "casio.com", select "support",and then "manuals", "watches" agree to the terms,
Select "Watch archive....."
Insert the watch number requested in the search box. This will give you a download of instructions for your watch.
How to adjust analogu time ?
32helpful
2answers
Lost maual to amw-700 casio watch
18helpful
3answers
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
