All the snaps/hooks are out as well as all the screws. Everything is loose except for the top near the wheel. How do I open the case to look inside?
THE final trick !!! just get off the front wheel ..CHECK THE PARTS MANUAL:
http://partsbooks.sewingmachine.com/Brother/Home/PL_BM2700AS.pdf
The page 9 .. take off the # 65 + 64 +63 + 62 then it gets free.. enjoy!!
http://partsbooks.sewingmachine.com/Brot...
off course.. first all the screws must be out first.
SOURCE: Brother XL-6562 Mechanical Sewing Machine
Dear jbanistr,
My wife and I just had this same problem (or at least getting the cover off) and have a possible solution. Safety first, unplug your machine from the wall. Next remove all the screws, three by handle, three on the bottom, one on the rear of the sleeve arm, one on the light bulb cover and one inside the lightbulb cover that goes sideways into the frame. I believe that's all of them but look for any that hold plastic-to-plastic or plastic-to-metal. Take note not to change the stich settings or else you'll have to find and set the number wheel and the adjuster to match, not fun. The way we did it was starting from the top, pry the case apart slightly and with a flat screwdriver gently lift the case over the three adjusting wheels so they clear. We then, with difficulty, pried the case the rest of the way open, with a really loud pop! A better way might have been to start pring from the bottom, but it worked. Reassembly was just the reverse, just fit the top first and put all those screws back in.
Hope this helps.
SOURCE: I NEED BUY THE BOBBIN CASE XL 3750 BROTHER SEWING
No problem, go to a Brother repair shop and buy one.
SOURCE: Brother SE270D
brother se270d the spring came off the mechism that come down and threads my needle. On the side of that foot is a hook for the spring and from that point I don't know where the other end of the spring go to! Help
