Toshiba is a popular name in the world of technology, and the printers, servers, desktops and notebooks the company makes are widely used in both homes and offices. While most of the time these Toshiba laptops will run without problems, there are times when laptop owners will need to take their computers back to factory new condition. In order to restore your notebook you will first need to get a copy of the recovery disk.
Turn the laptop over and locate the serial number label. The serial number label should be located on the bottom of the case. Open up the laptop and look for the model number. The model number should be located along the top of the keyboard. If the model number is not listed there, look for a model number label on the bottom of the case. Call Toshiba tech support at (800) 457-7777 to order the recovery CD. When calling, you will need to supply the representative with the serial number of your unit. You will also need a credit or debit card to cover the cost of shipping. http://laptopforums.toshiba.com/t5/Drivers-and-Utilities/Restore-disk/m-p/49692 Hope this helps.
SOURCE: put two gegs of ram in my toshiba satellite a55-s1063
1. The ram you put into your computer man not be compatible with the computer itself. You can find out what kind of memory your computer takes by doing a google search or asking a technician at your local computer store.
2. You may have put too much ram in. www.pcmemorystore.com sells as its largest ram chip for your computer a 512meg stick. This likely means that the most memory your laptop can take is 2x512meg, or 1 gig.
3. The memory may not be correctly seated. Installing memory isn't rocket science, but you have to make sure you have the chips seated properly before trying to boot your machine.
SOURCE: toshiba a55-s1063 wont read recovery cd. i tried a
Possible some of the program files have gone missing. If your recovery is not worrkingg, if your restore point is not working then the OS might have to be reinstalled.
SOURCE: How to do full recovery on Toshiba A55-S1063 Satellite Laptop
http://www.ehow.com/how_7617197_restore-discs-toshiba-satellite-a55s1063.html
Ever try Googling?
The best method is to reformat the drive to ext4 and install Linux. This will permanently solve your virus and corrupt registry programs by removing the cause of 96% of computer problems, Windows!
