update,Visio XVT553SV TV turns on, BackLight comes on. Audio works fine. Channels change, Just no Vidio.update,Visio XVT553SV TV turns on, BackLight comes on. Audio works fine. Channels change, Just no Vidio.
You can't post conmments that contain an email address.
The camera output would have to be composite---and if so go to one of the rear audio/video inputs: yellow (composite video) is likely all you would need unless the camera has audio as well (go to red or white on same input).
Some of the Newer VHS/DVD units don't have cable inputs. If this is like yours you can hook a RCA Audio/Vidio cable from your Samsung TV Vidio/Audio outputs (if set has them) to VCR/DVD inputs................... Larry
The RED (Right Channel), and White (Left Channel) are for feeding the Sound to the TV, The Yellow is for coposite Video. Check that connection. Also look at the venting grill to see if you can see any white lights inside, if no light, then the backlight inverter board may have gone out or it is not getting the power from the main power supply.
hi.. Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video Red= Audio right White Audio left
Also
make sure that the tv matches the input your cables are connected into.
I would make sure the restart the PS3 to make sure the video is good
(after checking the tv input)
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
If your camera has audio vidio cable (just get a cheap one which has a yellow, red and white connector) connectors. simply plug them in the audio vidio out on camera and audio vidio in on TV and thats it.
Let me know what type of connectors you have on your camera?
THanks
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
