I recently recorded approx 1 hour of footage on my SONY HVR-Z1E Camcorder, and when I tried to play back the footage all I can see is the timecode and a blue screen. But when I press the play button and then press the fast forward button I can see the footage, I can only see the footage in the fast forward mode. The tape I used was a SONY Mini DV tape and was brand new tape, and I've since tried to record on the same tape with success.
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
SOURCE: Lines through the tape when recording or playing back
It could need a head adjustment. Any camera store can do that for you.
SOURCE: sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
SOURCE: playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
