Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just replaced the lamp in my Sony projector with the recommended LMP-H130. Two problems. 1. I, my wife and my son all agree that the picture is not as bright as it was prior to replacement and 2. I cannot reset the lamp timer in the projector for the life of me.
  • 1 more comment
  • Anonymous Jan 30, 2009
    We have the same problem the replace lamp light keeps coming on and our color is all screwed up.
  • Anonymous Mar 08, 2009
    same thing here, i replaced the lamp, and the picture is much darker. every time i turn it on, i get a replace bulb warning and do not know what to do.
  • Anonymous Mar 25, 2009
    Same problem. Great projector! Needed a bulb replacement after 2300 hrs. So, I replaced both bulb and filter, but the screen is MUCH darker, even with the brightness all the way up.
Computer Links
Level 3:
  • Sony Master 2,386 Answers
  • Posted on Jan 16, 2009
Computer Links
Sony Master
Level 3:
Answers
2386
Questions
Helped
718470
Points
7718
This is our chat session, please rate it inappropriate it will spoil my rating.
vsurg: thanks
cmptrlink: welcome
vsurg: I purchased the bulb through electrified.com. OEM replacement for $249. Is there a difference between bulbs?
Read more cmptrlink: yeah the lamp should be purchased after proper specifing the device model, or the recommended lamp specified by the vendor
vsurg: It is the right lamp. Of that I am sure. The projector is a Sony VPL-HS51.
cmptrlink: hang on i will tell you the correct lamp number
vsurg: Manual says LMP-H130.
cmptrlink: is that the same one you got?
vsurg: Yes
cmptrlink: why dont you consult to a authorized sony service center.
cmptrlink: the lamp no. LMP-H130. is correct. but there must be some problem with the lamp or projector! is the lamp was packed when you got it?
cmptrlink: the projector normaly comes with 3 year warrenty
cmptrlink: To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this
cmptrlink: is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
cmptrlink: hello
vsurg: I got disconnected
vsurg: how do i get back on?
cmptrlink: hello sir
cmptrlink: are you there?
vsurg: Iam back
vsurg: How do I get back to the live session?
vsurg: I think I figured it out. I am back
vsurg: Please respond. I can't keep this up much longer
vsurg: How do I get back to a live session please?
Reset bulb timer on sony lmp-p200
1,Connect the power cord
2,The On/Standy light is red.
3,Press the following keys on the Remote Commander or on the projector in the following order for less than 5 seconds :Reset,left,right,enter.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Sony projector xga indicate lamp cover
there is an conductor under the cover,
pls push it down ,
and turn on the projector
Have a nice day!
Jerry
Lampdeng Limited
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
1helpful
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
1helpful
2answers
How to reset lamp counter of sony grand wega tv
Try calling Sony:
US:1-800-222-7669
Canada:1-877-899-7669
I found a manual online but says nothing about resetting the timer so call them and they should be able to walk you thru it.
1helpful
Sony projector - replacement lamp counter
  • Set the projector in standby mode.
  • Press the following buttons on remote control in following order for less then five seconds each...
  • RESET,
  • ENTER
Lamp timer is reset now.
This is also mentioned in user manual page 50
Thank you.
Sony VPL-ES3
What documents you need for VPL-ES3, let me know please.
Have you replaced Lamp? give details of projector problem to find out solutons.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
