Question about Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop
How to make Vista to recognize my old Hard drive
Hey all, Accept my apologies if this question was replied else where. Win Xp crashed and I replaced it with Vista. I formatted my old hard drive to install my Vista and tried to keep my SATA 2 Western Dig. HD with my data intact. Unfortunately Vista will not recognize that the 500 gig drive and signals that I should reformat it. Can I avoid reformatting the Harddrive? I am running an AMD with 1 gig memory so I should be able to do this right?
  • Dinoza
    Dinoza Jun 20, 2007
    Thank you both for the excellent solutions.
  • 196 Answers
Are the drivers installed for this drive and the motherboard? Look in Control Panel/System/Device Manager/Hardware for any yellow marks (Or whatever indication Vista uses for missing drivers). You may need to download these drivers from your PC manufacturer's website.
Posted on Jun 18, 2007
    President:
  • 2,961 Answers
There are normally only two ways to get vista to recognise large drives and that is to format it within windows by way of right click my computer then click manage and then highlight your harddrive right click and select format. The other way is if your drive isnt being recognised because of the bios and needs updating, as most bios chips did when upgrading to vista.
SOURCE:
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
I have a Samsung external 3.5 floppy drive, a SFD 321u which has worked fine in my old Win XP computer. I have a new system with Win 7 and this drive will not work with the drivers on the CD and Win 7...
If it is a USB external drive it should be recognized by your laptop, it worked for my dell floppy drive from xp to win 7 64bit, if it does not you should download the winxp driver and use it to install in win 7 when it does not recognizes the drive.
-select have drivers
-select downloaded drivers
it would give you an error of pop up saying drivers are not "signed" just go ahead a accept that and it should work.
Let me know if it helps
Mar 17, 2011 | Samsung SFD 321U External Floppy Drive
Hawking HWU8DD Vista Driver crashing Win 7. I just purchased new desktop running Win 7. Old system ran on XP. XP Driver would not work. Installed XP driver. System runs for ~10 minutes and crashes...
there will be no win 7 driver as win 7 is no longer supported by Microsoft
to get a driver , you have to go to the manufacturers web site , find a down load for that model that is compatible for win 7 operating system
win xp is also not supported by Microsoft so there will be driver problems there as well
Dec 18, 2017 | Hawking Hi-Gain Wireless-G (HWU8DD)
Model ST315005FDM201-RK 1.5 TB external hard driver needed
Win 98 simply cannot address a drive that big. There is no way to make it work. The "Other" PC's must be running either XP, Vista, or Win 7 all those CAN address that size drive.
Feb 26, 2010 | Computers & Internet
WIN Vista PC recognizes Roadmate300, but Roadmate Manager will not recognize it. Need a Vista USB driver? Other? Thanks much. Bill T.
some software only works with XP go to megellan web sit you may need to buy the update for vista and windows 7 on CD. and if you plug the GPS into a PC that doesn't have XP it could crash or not work at all
Oct 28, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My Transcend StoreJet 500 GB external disk is not being recognized by my Win-XP System. No Messages, and No Errors Too.
first try to connect it from usb port at backside of cpu. if it works well ....ten do reply me .....
Sep 30, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Unable to reinstall XP after Vista upgrade
If u have win. vista installed in ur laptop than u cant install win xp............if u install win.xp than ur vista will b dissappear from boot menu
if u want to overcome this problem than buy a software VISTABOOTPRO
and install it in XP it will help u
OR u can ask me for free soft.....
Sep 12, 2009 | Compaq Presario Notebook
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does. If you Google the problem you will find many solutions on how to rectify the situation. Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally. The other alternative is to leave your existing XP installation in place and add the new disc. Later you can clone your old disc onto the new drive and then remove your original disc.
Feb 11, 2009 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Hard drive crash
The guy that told you it would only cost $40 is not telling the truth. Windows XP runs around $125.00. If you download an operating system from the web, Microsoft can see that your copy of Windows is not valid and disable your system from a remote server. I recommend buying Win XP from Best Buy. It is currently on sale until Jun 26, 08 for $99.99.
Jun 18, 2008 | Acer Aspire 3680 Laptop
New computer with vista
hey this sounds like vist needs updated drivers to recognize that piece of hardware you have to remember that not the things that worked with xp will work with vista go to the manufacture that made that usb hard drive and get updated drivers this will help
Nov 03, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop Logo
334 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
