SOURCE: I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
SOURCE: Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
