I have a big problem in my monitor Compaq WF1907v turns off and on itself by eletric current when i turn on its ok but 5 minuts later turns off itself and i dont know what should i do I already took it to a technician but he cant fix it too its because the is because the power supply I think but pls help me im waiting answers.!
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
SOURCE: Power supply for Compaq 1501 15" LCD Monitor
arrange the manual from any where with same model and find it .without looking directly i cannot advice anything try to understand
SOURCE: HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
SOURCE: my new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
SOURCE: my hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
