I just received this camera. It appears to be in good condition, other than the fact that it does not advance the film when I load. It displays 'Film' and '0'. I suspect it is because it is stuck on rewind as I can activate the rewind mode by sticking a piece of paper into the mechanism. The little grey 'lever' just below the display is pulled all the way to the left, when ordinarily I think it is supposed to be pushed in. I cannot manually force it back into place. Any help would be appreciated.
SOURCE: Unable to rewind film in camera
Well, I used to work at a camera store and actually encountered this a number of times with Minolta's. I can't remember if the motors wore out or if the film slipped or tore at the track. The solution: take the camera into a darkroom or pitch black environment and remove the film by hand. Bring a pair of scissors and a black film container just in case the film tears or the track is torn. Obviously be careful to ensure no light is available if you can't access a darkroom. Check the bottom of the camera for a small button that disengages the motor gear (some newer models may not have this)(you may have to hold it in). Open the film door and with clean hands, use your index fingers and thumbs carefully on the tracks only and pull evenly. You may feel some resistance from the motor and hear the motor but if it won't budge check again if the bottom of the camera has a film release. As you do this feel for torn areas in the track which may indicate a motor malfunction or improperly loaded film. Now just wind the film back into the canister unless the track is torn. You may want to leave the leader out, and you should probably have the film developed right away for a list of reasons. If the track is torn, cut it off at the canister and touching only the edges roll it up and put it inside the plastic film container. Mark it "open film", or Open only in darkroom etc. and mention it to your developer. Alternately you can just hand over your camera to your developer who will do all of this for you...
SOURCE: Minolta X370 film loading problem.
First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs two 1.5v batteries to work ! )
SOURCE: film advance lever stuck
This sounds like shutter release problem and can be fixed by replacing a 3v 220 mf capacitor ( leaking by now because they do not last more than 8-10 years and your camera is 25 years old ). You can do it your -self but will need a soldering iron and a replacement capacitor : remove bottom cover and locate small ( usually black in colour ) capacitor on the right hand side of the camera. Unsolder -- keeping an eye on polarity which is marked on the outside of the capacitor-- and replace with new one. Switch camera on and it should release the shutter and you are back in the saddle.
SOURCE: Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
SOURCE: The film advance lever is stuck on my minolta
Here are the most likely:
A. Lever will not move on some models if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY, then the most likely is this...
Two capacitors in these Minoltas die over time. If you are handy at such things, you can buy the caps, remove top and bottom covers, remove the dead caps and solder in the new ones. Don't Panic.
You can find instructions on the web for this well known issue, and you can also opt to send it to a camera repair place. Garrys camera repair in Niles, ILL does it for about $58 incl return shipping. He will also clean, lube and adjust it for ya. Something they all need eventually.
