SOURCE: i don't know the security code of nokia 5130-c2
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
SOURCE: Hello sir, Plz help me.. I forgot
Hello and Welcome to FixYa!
The Default security code of Nokia is 12345 or 00000.
If you have changed then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here.
Give your IMEI No there and calculate your master code and try it.
It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
After getting your Cell info and charges, they will send you code.
If you don't want to then you can contact to NOKIA SERVICE PROVIDER to solve your problem
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
SOURCE: sir.....i use nokia 2600 clasic,12345
Security code lost means, you get the master reset code for that one.......
you can get the master reset code for your Nokia model mobile, through this site http://www.onlinegsmunlock.com/nokia-dct-master-code-service/rs7wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
SOURCE: i have forgotten security code of my nokia 6233 cellphone.
Please try with this *#7780# , you have to type this code on the main menu, note that it is done without sim card or you'll loose everything saved on the sim card. For more details please check out my tips and tricks page. http://www.fixya.com/support/r4739201-nokia_mobile_phones_security_secret Good luck. Thanks for using FixYa.
SOURCE: Nokia 6030 Security code required???
i have a nokia 6030 phone and whenever iam trying to restore my factory settings by the default code 12345 its not working properly
Nokia c2 security code error serial no:(359062/04/397978/7)
How to get my radio on
351726969199102
