HEWLETT-PACKARD Compaq Presario CQ56-129NR Notebook PC Logo
A
Anonymous Posted on Dec 22, 2012
Need wiring diagram for compaq presario cq56 power supply input
Need wiring diagram for input on the laptop side of plug
5 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Mar 22, 2011
SOURCE: THE SOUND ON MY COMPAQ PRESARIO CQ56 HAS STOPPED
chrisojari,
Hello, Welcome to Fixya.com, We are here to help you with your sound issues.
First check and see if its muted there is a tray icon to your right hand side by the clock on you windows operating system. Make sure its not mute by clicking on it (right mouse click) then go to playback devices.
Make sure there is no mute button pressed anywhere on the system for example some HP's have a mute button on the keyboard area.
Please update me and let me know if you have any issues.
We do hope this was very helpful advice. Sometimes you may need further support we do offer chat support, Phone support for a one time fee witch can get you going!
Thanks for using Fixya.com
Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Michael Vincent Cruz
  • 868 Answers
  • Posted on Apr 07, 2011
SOURCE: where does the sim go
Hi tefordgal12,
I see you have a SIM that you want to use on your compaq system, I checked in you system specs online and it does not show that it has a 3g modem on it on the issue.
  • On all Laptops the 3g modem can be found inside the system, if you remove the battery you may see a slot for a sim card in the battery bay.
  • All Laptops have the 3g modem in the battery but not all Laptops have a 3g modem installed on it some may have sim slots but does not have the 3g modem installed in it
  • Call HP regarding this concern since they can answer our question most accurately if you give them the serial number of your Compaq Laptop.
I hope that the information I provided helps.
Thanks, have a great day.
Anonymous
  • 212 Answers
  • Posted on May 26, 2011
SOURCE: How do set my Compaq
See my response to a similar question here: http://www.fixya.com/support/t9309853-porbolem
It's essentially the same answer for your question.
Anonymous
  • 8 Answers
  • Posted on Apr 01, 2012
SOURCE: problems with compaq presario cq56
open f10 go to diagnostics 10008 bios code means the hard drive is fried new one for cq 60 160gb hard drive 90 dollars but might as well upgrade 500gb only 115 i would think the cq 56 should be about the same price
Michael Kennedy
  • 233 Answers
  • Posted on Nov 06, 2012
SOURCE: Hewlett Packard Compaq Presario CQ56 power/charge light blinking orange & will not charge
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Compaq Presario CQ56 Notebook PC. DC power harness wire pin out please?
Unfortunately, it is not possible to provide a definitive answer to this question without knowing the exact model of the Compaq Presario CQ56 Notebook PC. Different models may have different pinouts for the DC power harness. You may need to consult the user manual or contact Compaq/HP support for more information.
HP Presario CQ56 wire diagram for the DC power unit
A mains cable is $5.80
https://www.newegg.ca/c2g-6-ft-black-power/p/N82E16812196313?item=N82E16812196313
There are only 3 connections on that, live neutral and ground. The wire on the other end or the mains transformer has a single plug with live and neutral as shown here. Not sure where you are finding 7 wires?
https://www.battdepot.com/ca/model/notebook+adapter/compaq/presario+cq56-200sg/ac19v90k3.aspx
Don't start messing with the motherboard connection over $5.80. Head down to Goodwill, you find them for $2 complete.
I need wire diagram for my compaq presario cq56
Contact Compaq/HP support and ask. Include pics if possible.
External monitor has no input signal
You can't just attach an external monitor to most running laptops. Nothing will happen. You must attach the monitor when the laptop is off, then start the laptop and it will recognize the external monitor and send the video to it.
1helpful
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
What kind of video cord do i need for a compaq presario cq56 laptop? my tv is a proscan and in the back of it it has a five prong
The only way of connecting your laptop to your tv, is through the VGA port on the left side of your laptop. Your tv must also support a pc input, via a VGA connector, if your tv does not have a pc input, your out of luck!
1helpful
2answers
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
