Currently TV and AV receiver come on with "Watch TV", and there is faint TV sound from the receiver, but volume not adjusted with "+" and "-" volume button on remote.
This is a problem with my father's remote and he has significant memory problems. He doesn't live with me, so I will need to give him instructions over the phone. I'm hoping that it is a simple solution.
Thanks.
SOURCE: harmony 880 remote will not turn on my dish 622 satellite receiv
Have you tried contacting your dish people, maybe they can reset.
SOURCE: Logitech Universal Remote
Please try adjusting the Power on delay before testing any other settings.
SOURCE: No sound from AV when watching TV after replacing remote batterie
Hey!
I have found that when my Harmony remote will not work with any of my devices, a firmware update will get it working again. If you dont know how to do that, just look at the link below:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
Hope this helps!!
-Kennedy
Testimonial: "Thanks for the recommendation. I'll do the update."
SOURCE: My remote froze up last night when I was trying to
It is probably not the TV, the receiver or the remote. It is most likely the actual Comcast DVR. I assume you have the DVR going into your receiver, and then the receiver to the TV for video, correct? Most likely it is the actual DVR that is having problems outputting the audio. Do you know how it is connected to the receiver? Is it using an HDMI cable, an optical cable...? Let me know and we can further figure it out.
The good news is, is that the comcast box is under full warranty through them so you can get a free replacement if that is indeed what has failed.
Let me know, just reply here and we will get this figured out.
Thanks
Tim
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
