Mitsubishi WD-73827 73" HDTV DLP TV Logo
Posted on Dec 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
I cant get sound to my tv tried different cords different chanals even tried unpluging the tv for 30 sec. nothing worked
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Dec 22, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718440
Points
48227
Check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
5 Related Answers
Anonymous
  • Posted on Nov 24, 2009
SOURCE: Just replaced the bulb in my wd-62528 dlp tv,
Hi, I'm not a service expert. I too own a WD-62528 DLP TV with exactly the same problem. Manufacture date Nov. 2005.
I have found in another forum (CNET) that this is a very well known problem. And that Mitsubishi (MDEA) is not taking responsibility for it. A group of people tried to make a Class Lawsuit but it was rejected. Also other people found that this TV actually does not display 1080i resolution, that is a separate problem from the lamp issue.
If you are able to solve this problem with the TV (blinking lights requesting a new lamp all the time and TV turning off by itself), please let me know. If you want a link to the other forum, let me know and I will send the link.
Also, please don't be discouraged from trying to find a solution. Keep trying.
Jorge Aguilar
Houston
Anonymous
  • 58 Answers
  • Posted on Apr 18, 2009
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Anonymous
  • 139 Answers
  • Posted on Mar 06, 2009
SOURCE: verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Anonymous
  • 146 Answers
  • Posted on Nov 20, 2008
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Anonymous
  • 3130 Answers
  • Posted on Jun 16, 2006
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
Cloudy
Sounds like a issue or problem with the optical light engine in the set, it is of course the most expensive part.
Mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
8helpful
3answers
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
1helpful
2answers
Can hear the sound on my 73 inch mitshubishi, but no picture at all..no black and white..nothing. After a few minutes the led red light in front that says "Lamp" comes on? What's the problem and how do i...
you need to replace the lamp inside the DLP TV. they are about $400 or so depending on your are. i would google the best price and find the must trust worthy TV repair place or call best buy.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
