Running windows 7 but have to hard start computer to wake the computer
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Thank you Brian Sullivan for your reply to my Windows 7 sleep mode problem,...
I understand what the sleep mode should do but mu problem is that when I try to get the computer out of sleep mode it freezes up and I must turn off the power & restart the computera
you might have a virus or malware or to many programs running at the one time you might uninstall some unecessary programs that could be clogging up your computer
http://www.majorgeeks.com/Microsoft_Secu... microsoft security essentials your operating system must be registered
SOURCE: my hitachi hard drive dosent show up in my computer
The reason it's not showing up in XP is because microsoft made updates to drive handling in Windows 7.
The disk is in essence too "advanced for XP"
Your best solution is to copy the data off the drive onto the windows 7 machine, then format the drive using windows XP. Once formatted, copy your files back onto the drive from the windows 7 computer and both will be able to share the drive.
Hope this helps FixYa,
Crankstart
PR: wait...
I: wait...
L: wait...
LD: wait...
I: wait...
wait...
Rank: wait...
Traffic: wait...
Price: wait...
C: wait...
SOURCE: I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp
you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
SOURCE: computer wont recognize external hard drive
try to format the external HDD using command prompt.....
type "cmd" in start & search box and hit enter...
command prompt will be opened...
Now type "format X:" where X=your external hdd drive letter....
if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
SOURCE: Toshiba MK1234GAX 120GB hard disk creating problems
Hello, verified if your hard disk is properly installed in the closure, don't forget to format your hard drive in NTFS. if your problem persist maybe need to check your USB connections in device manager.
SOURCE: My lacie starck hard drive
You need to install some components like lacie desktop manager,intrergo etc that came with the original device
Look for them on lacie's webpage
GameSting
A menu opens.
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
