Will not charge the batteries but inverter mode works fine, checked the internal fuses and found them to be ok. Also 25 amp circuit breaker fine.
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
When the remote panel shows a red battery state, the DC amps are < 10, and the fan isn't running even when power in is applied, that says the unit is not charging. I recently had the same problem with my Freedom Marine 25, and the culprit was a blown relay (blackened burn spot) on the AC sensing card, which was $400 parts and labor at a Xantrex authorized service center. Being reasonably competent in electrical matters, I uninstalled the 50 lb beast, carried it in, and reinstalled it myself. If you can get somebody to sell you one you *could* replace the card yourself, but it took a trained service tech an hour on a test bench to do it, so for my money, not worth the effort and the risk that it might not fix the problem. Just be very careful; one wired misplaced on reinstall and you could fry the entire unit.
same unit exact same problem my remote panel shows red battery state during attempts to charge when charge selected off, battery state shows amber on remote
Hi guys!I too have the same proplem!!I've contacted tech help,these people from India are worthless!!!!If you find the problem can you please contact me at [email protected] alot,Kelly
Inverter works fine, only do not charge the chassis batteries. It is an 11 year old unit and it is in a fleetwood coach. Coach batteries seem to be ok.
We bout a fleet-wood expedition with the same problem. going back to see if the dealer can fix.
