Computers & Internet Logo
Posted on Jan 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi? - Computers & Internet
  • Shamsh May 11, 2010
    yes how can i assist you.
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Jan 16, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153301
Points
8370
Laptops will only get you high (hi) if you sniff them. They're a bit chunky to get up your nos though.
1helpful
2013 Heritage Softail Hi beam switch does not stay engaged.
The spring-loaded detent in the switch itself sounds like it went.
You might buy a new switch and replace.
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
1helpful
Can get analog stations recorded but not hi defination
Hi, unless the VCR/dvd recorder is hi def then you won't be able to.
Hdmi connection is hi-def, I think you can have a hi-def signal through composite, but it's your recorder thats the problem, it cannot read the number of line a hi-def signal has.
I have just found this.
http://www.brighthub.com/electronics/home-theater/articles/48499.aspx
I hope this helps.
Regards - Anthony
Hi...
hi i lost my windows xp product key.plz help me
1helpful
Four wheel drive engages from 2 hi to 4 hi on its own whe driving
I had this problem also, disconnect the battery a leave it for a while, this reset it,
only draw back somtimes it will reset idle also and vehicle will stall, to fix this just let it sit idling
for a bit and it will relearn the settings
Vibration!!!
It could possibly be a bad motor mount.
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Grand Canyon Tech
Grand Canyon Tech
