I have added some numbers to block list . but now i am not able to remove them.
SOURCE: How to Block a number
Go to menu then settings and click on call settings. Then go to all calls and auto reject should pop up. Then you just add the number to the reject list and activate your list. And make sure the box by the number has a check mark in it or it wont work
SOURCE: Want to block a number from calling my mobile
call up your service provider and have them block the number. this should be a ten minute task
SOURCE: Blocking Calls
No, actually, there is no way of blocking text messages, just incoming calls. Cheers
SOURCE: remove no from reject call list
From page 83 of the manual...
At "idle" screen press menu key
Go to "Settings" and select
Scroll to "call settings" and select
select "all calls"
scroll to "auto reject" and select
At this point you can go under "Activation" and turn the feature on or off.
or else...
scroll to "reject list" and select
Here you can add, remove, or edit numbers to reject.
