Firmware
SOURCE: smsung yp k3 qb/mea firmware problem
You will need to return it for a replacement. Don't tell them the above as it would have invalidated the warranty.
SOURCE: YP-P2 FIRMWARE PROBLEMS
I had the same problem!
But I found the fix for it after much searching.
First, download the latest firmware directly to your computer's desktop from the Samsung website: http://tinyurl.com/3j4su4
The file is a Zip one so : make sure you extract the 2 files to your desktop!
-Connect your P2 to your computer and go to My Computer.
-Double click the YP2 icon.
-Copy the 2 extracted files from your desktop into the open window. (Do not put them in an already existant folder).
-Unplug the connection from your computer and restart your player.
It will do an update and shut down. Restart it a second time and it will finish the second update.
- There you go, it should work no problem.
The firmware update from having your player connected to the Samsung Media Studio 5 for some reason doesn't work properly.
By doing in manually it works just fine.
The update link I provided is for a US based player.
Just go through the Samsung site to find an update for other contries if you need too and follow the same directions I give above to solve your issues.
Hope this helps!!!
SOURCE: Samsung YP-K5JAB
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
SOURCE: Samsung YP-T9 problem
look buddy first u shud get rid of the shorting out on the usb connection.
then get to samsung.com and check the support page of ur product and start downloading!!
