I can't seem to get the tension right in this machine...there doesn't seem to be a way to adjust the bobbin tension. Top stitching is fine but the bottom is loose.
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Mine has the same faught.
