Question about Jet Tech Systems 24 in. 737 Free-standing Dishwasher
Dishwasher will not stop washing
The 737 Jet Tech will not stop washing or drain. You have to open the door and get wet to stop it, then use the white drain button to let all the water out. When you try to close the door to allow the unit to heat up, it automatically begins to wash again........
After 20 mins water temp still not at 150 on my jet-tech 737 dushwasher.
The reason the temperature are going up is the heating system is defective. The thermostat on the booster (rinse) is not satisfied. First thing to verify is the contactor that is activated by the rinse thermostat. Often one of the wires on the contactor will burn.
Nov 20, 2013 | Jet Tech Systems 24 in. 737 Free-standing...
Jet tec f18 water goes to 120f redy light does not come on will not wash got hot water to 120f open door have steem but no wash frank
Verify the contactor for working condition. maybe burned wires or bad contactor. if it is good then the rinse thermostat or, less likely, the booster element.
Oct 07, 2013 | Jet Tech Systems 24 in. F18DP...
E1 on jet tech 737dp
How do I find those wire in the machine?
Oct 23, 2012 | JetTech Jet Tech 737 - Undercounter...
The drum stopped spinning, but could still hera motor running. The door was locked; could not unlock to open. After several attempts of unplugging/replugging door could be open.
Is this a dishwasher or a washing machine that you have a problem with.
The drum is usually in a washing machine. The motor you hear running is the drain motor. So this is a normal operation of front loading washing machines. When the drum stops spinning, the drain pump takes away the remaining water and then a timer lock comes into play to make sure the clothes are settled dowm before you can open the door.
So I do not see there is any problem. Please accept the solution if ok else post a comment to confirm the exact problem with your appliance.
Mar 21, 2011 | Dishwashers
Water to dishwasher not hot enough
The 737 model could run on even lower temperature (80F). Given time, the unit will heat up the water. the trick is to give it time.
That model is made for commercial use, not really for residential. It will not fully drain every cycles. The important thing to keep in mind is to empty the dishwasher (turn it off, pull the stand-pipe out, and drain) every night and left empty. When you want to use the unit, put the plug back in and turn it on, wait 20 to 30 minutes and it should be ready.
Robert Marsolais
Jul 28, 2008 | Jet Tech Systems 24 in. 737 Free-standing...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Jet tech washer 737 dp
Ouch.
Before you start changing all sort of parts, correct your problem with the wires. You may have to change most of them, depending on how bad the chemical burned tru them.
A good cleaning is required because that soap is going to continue chewing on those wires.
You're right about a short causing other component failure. But first repair those wires
Robert Marsolais
Dec 19, 2007 | Jet Tech Systems 24 in. 737 Free-standing...
Jet Tech Systems 24 in. 737 Free-standing Dishwasher Logo
260 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
