Is this mobo support NCQ?
if YES how?
main board Epox EP-AF550G Pro (4 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Video, Gigabit LAN)Chipset nVIDIA nForce 6100-430, AMD Hammer
IDE controler NVIDIA nForce Serial ATA Controller
thanks lot of...
If AHCI is not enabled by the motherboard and chipset, SATA controllers typically operate in "IDE emulation" mode which does not allow features of devices to be accessed if the ATA/IDE standard does not support them. Windows device drivers that are labeled as SATA are usually running in IDE emulation mode unless they explicitly state that they are AHCI. While the drivers included with Windows XP do not support AHCI, AHCI has been implemented by proprietary device drivers.[1] Windows Vista[2] and Linux with kernel version 2.6.19 onward[3] have native support for AHCI.
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
