Canon printer display the error E000 0000
SOURCE: selftest
Is your printer installed properly? You have to check "Control Panel" > "Printers and Faxes" It will have a list of installed printers and software like one note Can you see your printer name there? If "NO" then you have to install the printer Please leave a comment! I'll check it out
SOURCE: How to Refill the Canon
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
SOURCE: Canon LBP-2900 Printer Open top
It is very easy to open the printer.First you need to remove the screws at the back.Then slowly remove the white panels which is fixed at the left and right sides.You should be very careful doing so,because there is no screws instead of that only plastic locks.Then you can remove the top cover.The total plastic panel you can remove only removing the two screws.Best of luck
SOURCE: my printer lbp 2900 producing blank out put
my canon laser shot LBP 2900 gives blank paper after refilling of cartreage
