Started Okay, ran great, parked over night, Turn Key to start and nothing...Checked battery, low, gave full charge and still nothing when trying to start
SOURCE: Starter will not turn over
I had this problem and had my vehicle towed to two different places and was out a lot of money to find out it was the key. The security code had reset itself and the explorer acted as if it were being stolen therefore not allowing it to start. It has to be fixed by an authorized Ford Dealership. No one else has the ability to fix it. I hope this helps you not to have to pay two machenics for one problem. Thanks
SOURCE: car wont start, acts like
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
SOURCE: 2000 Ford Expedition, power windows and dome lights won't come on
2000 ford expedition passanger power window wouldn't work
SOURCE: Ford 2003 Expedition EB. Check Charging System
Its probably the alternator. It will need to be tested on the vehicle with the engine running and the light illuminated. Measure the battery voltage with the engine running. It should be at least 13.5 volts. If it is lower have the alternator tested at a shop with a charging system tester.
