Lines move up and down
Broken connection from the screen ribbon to the monitor
screen has become disconnected, mark the spot on the screen where the line occurs
and then dismantle the screen, remove the metal cover at the top of the screen,
which exposes the pc board and the ribbon connections. Where the markings of
the line is place a piece of rubber similar to (inter-tube material)over this
area, this should apply pressure to the area of the ribbon that has a
loose connection and hold it tight. The ribbon is bonded not soldered to the
screen. Reassemble and test.
