You will need to replace the lock assembly. Here is the part to order.
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
SOURCE: GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
SOURCE: ge xl44 after self clean cycle the door won't open
Unplug the unit or shut off the circuit breaker for 5 minutes.
Plug the unit back in or turn on the circuit breaker. Set the clock and gently
try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15
minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try
If these
procedures fail to correct the condition, the lock must usually be accessed and
moved manually to open the door.
Some model
ovens require the oven door to be manually unlatched before the controls are
returned to the OFF position or else the door may not be able to be unlocked.
Check the owner's manual for proper operating procedures.
SOURCE: Oven door after self clean cycle won't unlock
Both the oven" ON " light and " Clean " light will flash when the clean has finished . When the " clean " light flashes , slide the latch handle to the left as far as it will go , then turn the " OVEN SET " knob to " OFF " to open the door.
