I got my brand new serger almost 2 years ago and i havent really had a good connection with it. i have done, tried changing needles and threading it right but it still doesnt serge as it should be. the loower looper thread keeps breaking. i havent done any work with this cause im afraid it might destroy my projects(thats actually happened a lot of times) please help me.
Sergers are... well can be a pain. "Lower looper thread keeps breaking." Ok... so Here is what I Would do. Get your magnifying glass out and really get in close with a good light and look for burrs on the looper. Also look for burrs on the throat plate, etc. If you find one use some very fine sand paper and carefully smooth it off.
If that doesn't help or fix it. Take it in to a repair shop and tell them what's going on. you might need it timed too. Good luck
SOURCE: brother serger thread
The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
sewman7
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
SOURCE: I was wondering if you could help me concerning my
i was able to find manual at www.ifixmachines.com
SOURCE: upper thread keeps breaking
the tension is too tight give it a little slack on the top.good luck.
