It shows it`s charging but only shows one bar and doesn`t show it`s fully charged???
SOURCE: Samsung KP-K3 MP3 Player - Charging battery
wen i first got myn i had the same problem i plugged it and left it plugged in for a couple of hours and it showed there bars and was fine i dont quite no wat i did but i suggest double checking you have plugged it in prople sorry if im no help x
SOURCE: Charging the battery on Samsung Upstage sph-m620.
Well if it's new, then I would take it back to the store from where you bought it. It will be under warranty so, if something is wrong you should be able to get it swapped out with a working one.
SOURCE: battery not holding a charge
Hi try this I had a new Blackberry which required charging every single day, take out battery and press and hold the on button on the phone for a min, then put battery back in and try charging again! mine is perfect now again.
Somebody told me that it's to do with static or something that builds up and flattens the batt.
SOURCE: Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
