Question about Dell PowerEdge 1600SC Server
My raid 3 controller has failed on my dell P/edge 1600sc how do i repair same
  • 1,555 Answers
Get a new one, you can not repair them.
Posted on Jan 29, 2014
5 Suggested Answers
SOURCE:
SOURCE: Memory and RAID Card for a Dell 1600SC
May be worth reseting the bios using the on-board jumper.
Posted on Jun 01, 2007
  • 3940 Answers
SOURCE: how to install win2003 server freshly on dell power edge 1600sc?
You'll need to load the SCSI hard drive controller driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PWE_PNT_XEO_1600SC&os=WNET&osl=en&catid=&impid=
Posted on Aug 06, 2008
  • 98 Answers
SOURCE: New hard drive won't go online on our Dell RAID server.
This needs to be reconfigured again. My suggestion is to call DELL again so that things happen they can still able to do the replacement of the hard drive.
Posted on Oct 06, 2009
  • 64 Answers
SOURCE: my dell server 1600sc power
if the system has no redundant power supply.
basically you will need to replace it with the same make and model from Dell or a working 2nd hand model.
Posted on Oct 07, 2010
Need to increase the hdd size in a dell poweredge 1600sc with raid 1
You will not be able to increase the hdd size of a raid array, it's size is set. If you need more storage, you can add additional drives ( either in raid or standalone ) and use the new drive(s) for storage, but the original array will remain unchanged. The other option is to back up all of your data, install new drives and create a new array.
Feb 10, 2011 | Dell PowerEdge 1600SC Server
Having a raid 5 problem, either in raid controller or raid cage backplane. Can it be fixed and what is the price.
What is the problem? If you give a more detailed question we can give the correct advice!
Sep 07, 2010 | Dell PowerEdge 1600SC Server
NO HARD DISK FOUND DELL POWERDGE 1600SC
Is the HD SAS/SCSI/SATA on a raid controller?
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
Either that or the drive(s) shafted.
What sort of disks are you using?
Aug 20, 2010 | Dell PowerEdge 1600SC Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
How do you silence the beeping from an failed raid array?
if you installed the poweredge management software (openmanage) you can setup the alerts in the disk management
Dec 21, 2009 | Dell PowerEdge 1600SC Server
Oct 06, 2009 | Dell PowerEdge 1600SC Server
Our 1600sc dell server is beeping continuosly.
Check the PowerEdge Raid Controller for parity problems. Sounds like the status on the physical volumes participating in a RAID array has been degraded.
Loud beeping from a drive is usually an indication that an invalid drive array member has resulted in a degraded logical volume.
If you were counting correctly, you had at least three drives - most likely participating in a RAID-5 setup. The array might have been rebuilt with one bad drive. But it sounds like you've got two corrupt physical volumes in the array. And that's not good.
Hope you've got a backup!
Jan 19, 2009 | Dell PowerEdge 1600SC Server
How to install win2003 server freshly on dell power edge 1600sc?
Aug 06, 2008 | Dell PowerEdge 1600SC Server
Poweredge 1600sc cant see other 4 drives
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Aug 05, 2008 | Dell PowerEdge 1600SC Server
Jun 01, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
83 people viewed this question
Ekse
Clive
Clive
