SOURCE: JVC GZ-MG275AA Everio Camcorder
Problem solved. I was thinking I could delete from the PowerCinema NE for Everio software program that comes with the camera but that is not the case, so it was just a matter of finding where all the video files were stored on the computer itself, ie, "myworks, Everio backup", and delete from there.
SOURCE: My 2 year old got ahold of my JVC Everio & deleted all the files.
OK generally the files aren't actually physically deleted... The software simply makes it so it can;t be found... usually simply by putting a $, or # sign in place of the first letter. So find yaself a freeware data recovery software and try ya luck... is a URL to get ya started..
http://www.undelete.in/
Good luck
SOURCE: can't transfer videos from JVC Everio camcorder onto my MAC
Share: How to import .tod files from JVC Everio HDD Camcorder to iMovie?
Requirements: iMovie (Part of the iLife 08 package)
Step 1: Connect the Everio to the Mac (Via USB)
Make sure you are powering the Everio from the mains before connecting your JVC Everio Camcorder.
Step 2: Playback on PC
Select “Playback on PC” on the Everio, once connected you will see the Everio HDD symbol appear on the desktop. The video files on the Everio are stored in the SD Folder/PRG***/MOV***.MOD.
Step 3: Open iMovie
Once you open iMovie, you will see that it recognizes the Everio straight away and will attempt to import your video.
You are now ready to use iMovie to edit your video files.
If need change .tod files to common video formats like mov, mp4, m4v, mpg, mpeg, dv, flv, avi, wmv, 3gp, mkv, mp3, aac, wma, m4a, etc. Mod Tod Video Converter for Mac is a good choice. The program can also convert mod tod to ipod, mod tod to iphone, tod to apple tv, tod to blackberry and more devices!
SOURCE: I want to use My JVC Everio HD camcorder for a web cam. Model GZ-MG130U
well, to convert the file from your JVC, u have to use a tool to do this. here i recommend u Pavtube HD Converter which can convert mod, tod, mts, m2ts to many other regular format u want. and if u wanna a web cam, u have to find a specific one for web camming.
SOURCE: Deleting unwanted files with a JVC Everio MG130 Camera
Answer:what you do is you press the play/record button on the left side of the camcorder when it is open to get to the videos. then you use the laser touch operation to scroll to the video you want to delete. then, right under the screen there should be 5 buttons. the one to the left of the menu button has a picture of a garbage can looking thing above it. just press that and then press yes when it asks you if your sure.
