Mitsubishi wd series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch amazon just fine. If I wait half an hour I can go back to regular cable for several more hours
SOURCE: Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
SOURCE: TV is 73" DLP Mitsubishi.
Hello
There are tow reaons for this fault. The first one is with the colour whell as you mentioned here. The second and most importan one is with its bulb itsef. Colour wheel won't cost too much. Just replace it first and see whether it helps you. If not, bulb may have to be replaced.OL
Already tried that. It is a 2005 73". Not sure why this says otherwise. Last night it didn't do it at all. But most evening everything is fine then for a few seconds it looks like it has a horizontal hold problem as from the old, old tv's , then it goes bluie. Turn it off for 30 minutes and all is better. When it goes blue I can also switch to the input for the Roku box and watch Net Flix just fine. As oppossed to turning it off i can watch NetFlix for a while then go back to cable and it is fine.
