The door on my front load washer hangs down to far and lines up below the latch slot. The door moves up and down when lifted to make the striker plate line up to latch the door. I often have to hold my knee against the door for it to lock and stop buzzing. Www have had the door assembly lock replaced by service tech assigns I have replaced the striker plateplate numerous times due to my children slamming the door shut. I think the door is lose because they lean on it to hold themselves up while loading the washer. Can you tell me how to fix this without calling a technician
Have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
SOURCE: Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
SOURCE: FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
SOURCE: accessing the door lock switch
spring clamp around boot (spring at bottom) pop off with screwdriver, pull boot off groove.
SOURCE: Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
