Computers & Internet Logo
Abdurhman Toulaymat Posted on Dec 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The wired computer keeps connecting to the internet .. but the wireless devices doesn't ..
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 20, 2012
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015211
Points
21773
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
5 Related Answers
Anonymous
  • Posted on Apr 08, 2009
SOURCE: Wireless range of DSL 2640U Wireless G ADSL2 ROUTER
hi
it is 100m maximum
mail2pvs
Pavan Ponangi
  • 390 Answers
  • Posted on Jun 24, 2009
SOURCE: vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Anonymous
  • 3 Answers
  • Posted on Sep 23, 2009
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
Anonymous
  • 5 Answers
  • Posted on Nov 08, 2009
SOURCE: I keep getting flashing red dsl light on my att
Its better once you reset the router and reconfigure
Anonymous
  • Posted on Aug 28, 2010
SOURCE: d-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Unstable wifi with router D-link dsl-2640u
Call Technical Support at 1-866-414-4714 TOLL FREE
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
My d'link dsl 2640u keeps disconnecting. i try to access the router throw 192.168.1.1 but nothing shows every time i need to restart my PC then everything would be fine and i can ccess the router...
Does your PC work on other networks reliably? If so- it's likely the DLink failing. The firmware issue is just a symptom as well. I'd recommend either seeing if you could use your DSL provider's original modem (if this was a replacement) or if you have another router- if it doesn't drop at that point, it was definitely the router/modem. However, if it drops still, you may have a line issue- but I severely doubt this since the symptoms are pointing to the DLink.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
How to configure my Airtel dsl broadband with dlink dsl 2640u router
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
1helpful
I want to change password on D-link DSL-2640U
Here is a direct link to show you how to secure your router, now you will need to reset your router to default settings before securing to do that press and hold the reset button located on the back of the router for 15 seconds or until router resets, you may need a paper clip to access the reset button.
http://ftp.dlink.ru/pub/ADSL/DSL-2640U/Description/DSL-2640U_B2_Manual.pdf
I have bought a wireless ADSL modem, Dlink DSL 2640u , How can I install and use it for another laptop? I want to use it without wire. Thanks
all wireless devices must be allowed in the router by either MAC address or by name. This is accomplished by logging into to the router and setting up the device in with the wireless setup feature in your router. The router will not allow the device to connect without permissions.
23helpful
3answers
D-link dsl - 2640u ' the lan is up but wireless no...
1helpful
I need to change the channel on my dlink 625 router..can u help?
I presume it's a cordless phone? If so, it's possible that it's interfering with the wireless signal. If that happens you will see the wireless connection being dropped - go into the wifi config utility and check how good the connection is. If this is the case, changing the channel may help. To do that,bring the router over to your PC and connect with an ethernet cable (just in case something goes wrong with the channel change and you lose the wireless signal.).
You need to find the "router homepage" in your web browser. If you don't know what it is, in windows click start -> run -> type "cmd" and press enter. In the command screen that pops up type "ipconfig" and press enter. It'll show you a few things. One should say "Default Gateway" followed by numbers.Write those numbers down (probably will be something like 192.168.1.254).
Open your web browser (IE, Firefox etc...) and enter the numbers. This will bring you to the router page. There should be an option like "Wireless" and under there you should see "change channel". It may be in the advanced option window.
IF your computer is NOT dropping the wireless signal when the phone rings, but the internet connection does drop - check the DSL signal light on your dlink. If it is flashing or not on, then the problem is with the DSL filters (small white connectors sent with your modem.). Always ensure any phone on the same line as the DSL is filtered or it will cause the internet connection to drop whenever the phone rings or is picked up.
3answers
Help with d-link wireless router
try a power cycle. unplug the power from the back of your modem. unplug the power from your router. shut down the computer. Plug the modem in frist wait until lights are normal. Check your cables make sure the modem is plugged into the wan port. then power on your router. wait until lights are normal plug in your laptop with a cat5 cable. start up the laptop see if your able to access the internet with the cable plugged in.
If so great your on line. open ie and goto your router ip address which i think is 192.168.0.1. its in your manual anyway. goto the wireless tab and make sure your wireless is enabled in the dlink router.
If your internet is not working then you need to setup your pppoe connection if your on dsl. and then do the wireless set up. default is usualy the ssid. [
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
